Matlab has an interactive demo that gives a nice visual illustration of the eigenvectors and eigenvalues of a 2x2 matrix. I thought it might be of interest to create something similar in Mathcad, hence the attached (done in M15).
Alan
Nice done. Alan.
You might consider adding an animation and maybe using a scroll bar instead of the slider so the changes are seen while the slider is moved. Richard has a very practical component in his collection here http://communities.ptc.com/docs/DOC-1071
Thanks. I considered an animation but decided against it because I think it takes a little time to assimilate the relationships being displayed and an animation would probably go too fast (plus, I couldn't be bothered to spend the time creating one!).
I'm happy for anyone else to add animation/scroll bars!
Alan
OK, why not. Done.
Hmm, found no way to add files. I was only able to replace your original file. So I restored the original version but there seems to be no real undo - its still flagged as my modification - sorry.
I could pack your original and the two new files in an archive, but I guess this would end up as an archive inside an archive - not nice to handle.
No worries! You could simply add your version as a different thread.
Alan
