I need to find roots of a periodic equation by making initial guesses of x and assign the derived roots in "a". But, Mathcad is saying " the value must be a scalar". What does "scalar" in this case and how can I solve this? I also need to sort "a" after assigning.
Thank you very much,
Faisal
Its always better to post the worksheet itself rather than just a picture.
How about this approach:
Worksheet in Format P5 attached
See my approach in the answer above
Thank you very much for your help. Can you please direct as what does "scalar" and "vector" means in Mathcad language. what I understand is one is in a matrix form and the other isn't. You can also direct me to any previously discussed topic about this.
A scalar is a simple value, like 15.6.
A vector is a n x 1 matrix, a column vector.
Obviously vector elements are not allowed in the "root" command which made is necessary to create our own "Root" command which does 😉
Thank you again
I am very close in getting my solution but I am having an issue. the roots that I am getting has some repetitive and negative roots. My solution only involves positive non-repetitive roots. I have tried this approach but not working. Could please see to it. Thank you. My Mathcad version is 4.0
Thank you very much, it worked. I truly appreciate your concern and time for this,
Thanks Werner_E for your very good Mathcad sheets.
Now I can use your Mathcad sheet and it is very helpful to understand the usage of Mathcad functions.
Tokoro.
