hi
ptc-5195719
hi
i am very new to the community , i hope it is not wrong place to open discussion,
here is my question on the pic, could anyone help me to calculate Q=P*T(s)
thank you
9 REPLIES 9
Hi
I'm not sure what you are trying to do. However, you have a definition for d missing. After supplying it, the sheet worked (see attached sheet).
You don't need to define the second matrix as a function of d.
Raiko
thank you for your answer Raiko, but d is not a integer, it is a variable like x . what i am trying to do is about sweeping a polygon to describe a surface.
i have to find q as a function of d
thank you
If you could provide the functions which describe the surface shape and some constraints we can try a solver such as find or minerr.
Raiko
Thank you Raiko.
I just have a polygon which is P and the question is
"sweep it along the straight line z=2s to describe a surface"
Thank you for your replies and interest.
You say it correct and so you have to write q(d):=P.T(d)
BTW, its always better to attach the worksheet and not just a pic.
Ah, yes, and a more meaningful subject may help, too.
Thank you for the answer Werner Exinger,
I am very new to the community and i will keep your advice in my mind.
No problem.
I think your inital question is answered but thats not what you are really after at the end, right?
No that is ok for now,
Thank you. I have to do some examples to get better about mathcad.
Ok, thought you wanted the surface to be plotted in a 3D-graph, too.
