interpolation
Raj_mathcad
interpolation
I am not able to get interpolation to work. See attached worksheet in m11 format..
Seems to be Mathcad did not like my knots vector..
Any suggestions..?
10 REPLIES 10
Any suggestions..?
There's no data in your worksheet, Raj. I created some arbitrary data and your worksheet seems OK. What problem are you experiencing (eg, error message)
Stuart
May be not interpolation but fitting - see the attach.
Sorry both of you. I believe the data on the table have been lost when I saved the worksheet in "mcd" format.
Here is my file again. I am getting an error "invalid interp. points"...
-Raj
-Raj
Unfortunately, Raj, I only have M11 available at the moment - can you post the data separately, as say csv or xls?
Stuart
MikeArmstrong
(To:StuartBruff)
There you go Stuart.
Mike
The result strongly depends on number of knots of interpolation. Look an attachment. If N doesn't exceed 5 or 6 results turn out satisfactory. At 6 <N <10 we have bad results between knots. At N>10 we receive an error message.
Viktor
Viktor
Intresting.
I only reposted the worksheet in version 11 for Stuart, forgot to look myself.
Mike
Thanks Viktor. But, I am not able to open your worksheet and it says "Failed to open document"..
Can you zip and attach it?
Thanks in advance..
MikeArmstrong
(To:Raj_mathcad)
Try this one. I successfully managed to download it.
Mike
Thanks Mike. It opens fine now..
