On 6/3/2009 11:08:13 AM, GuyBeadie wrote:
>On 5/31/2009 11:25:57 AM, adiaz wrote:
>>This can go in Puzzles
>>section:
>>Calculate lim 1/x for x->0.
>>Regards. Alvaro.
>I'm confused ...
My original intention was to show that CAS usual make the unusal assumption that values are reals taking limits. I think that this is a very hard assumption, and must to be more explicit in the help pages. Also, this happen (sometimes) with integrals. When I post the question I know that the better answer for the reals was unsigned infinity (even I despiste about the fact that implementation violates the principle of unitiy of the limit), and know that CAS have only two reals ininitys. Also, the mathematica implementation it's old and know this.
So, the trick in the question is making a well assumption about the domain of the function 1/x, and work in it. Because the default domain in CAS systems are complexes, this is then natural domain for this question.
> a true limit at (x,y) exists only ...
This is the well english words explanation about a limit.
Central point in your post is:
>By contrast, 1/z violates all aspects of that definition. In a small (complex-valued) circle about (0,0) the function values explode all over the complex plane! That's hardly a small deviation of the function value!
Explode in the interpretation of the complex plane that ... this is a plane. In the complex plane the better geometrical way to understand the infinities (for me) are the elements from the proyective geometry, who says that there are a lot of "improper" point (points at the infinity), one for each "direction" in the plane, and all fails into the "improper" rect line, the only one line in the complex plane that have all points in the infinity. Is in this geometry that I says that the limit of 1/z as z->0 is ∞ - i∞.
But there are other geometrical representations for the complexes. For instance, the Riemman sphere. With this we can destroy the explosion.
To do this, we must (i guess that it is a must) add the "point at the infinity". The beatifull improper line now degenerates in only one point. When you proyect the plane points into an sphere, the proyection of the improper rect line fails (with all the improper points representing plane directions) in the north pole.
So, the north pole kills a lot of information, for instance, all the directions go to same point (all the paths go to Rome).
In the Riemman representation, so, the lim 1/z is preciselly the north pole of the sphere, actually, a well defined point (for the sphere sense of well defintion).
Also, for continiuty questions in the 'sphere-well-defined-questions' is usual to add the north pole (called now "the point at the infinity") to the complexes defining C union {∞}. Maybe for analysis ∞ remains only as a formal symbol, but in the geometrical sense (the sphere sense of the complex numbers) actually it's only a only one well defined and accesible point (hard to arrive, but exist. Ask to Fridtjof Nansen if it isn't).
Resuming: there are presented this answers to the question lim f(x) as x->0 with f(x):=1/x
1. If Domain(f)=(-∞,0), ans = -∞
2. If Domain(f)=(0,+∞), ans = +∞
3. If Domain(f)=(-∞,+∞), ans = unsigned ∞
4. If Domain(f)=Complexes,
A. Riemann Representation: ans = ∞ (representing the north pole)
B. Polar Form: ans = +∞eiθ with 0<=θ<2π
C. Cartesian Form: ans = +∞ - i∞
I'm think that only the result 4.A. is which it is generating controversing.
Regards. Alvaro.
P.S.: Notice that the anser undefined for the result 3. kills information. For example: a*∞=∞ for a real not null and a+∞=∞ for a finite, but a*undefined=undefined and a+undefined=undefined. Also, Riemman representation do the same with the directions in the plane. There are an information theory question here: 1/+∞, 1/∞ and 1/∞ converges all to 0: right zero, left zero and 'unsigned' zero. 'Obviously', zero have not sign (or have?).
