I downloaded a trial version of mathcad 15.0, but can't get it to open any mathcad 14.0 files. How can I do this? Thanks, Amy
Are you sure you downloaded Mathcad 15? We have also posted the trial version of Mathcad Prime 1.0. You can't open earlier versions of Mathcad files directly in Mathcad Prime, and need to use the converter.
As Richard wrote, Mathcad 14 files should open direcly in Mathcad 15.
Do post a file that is giving you problems.
Mona
I am getting the error "the requested file is not a vaild mathcad XML worksheet"
The file formats in 14 and 15 are identical. Could you post the offending worksheet.
Mona
I greatly appreciate your quick replies. With the knowledge that mathcad 15 absolutely should be able to open mathcad 14 files, I figured out the files I had were corrupted. With valid mathcad 14.0 files, they opened perfectly. Many thanks!!!!
