mathcad 15 license transfer
cwalton-2
can anyone help? i want to transfer my mathcad 15 license to another computer, however when i use the license transfer function/reconfigure tool the mathcad 15 doesn't show up in the license report and isn't listed as an option to transfer (only my Prime Licenses). is there any other way to transfer the license to another machine?
10 REPLIES 10
(To:cwalton-2)
Your Prime license = your Mathcad 15 license. (You're licensed to Mathcad 15 because you're licensed to Prime).
But I could imagine they must both be on the same machine.
does this mean that you have n licenses of Mathcad Prime and another 1 license of Mathcad 15 ?
Did you buy Mathcad 15 at PTC ?
If you pay maintenance for Mathcad Prime then you can open Case at PTC Support and ask them to transfer Mathcad 15 license.
MH
Martin Hanák
Hi Guys
Correct i have 4 Prime 2.0 licenses and one Mathcad 15.
I'm not sure where it was purchased from but it was purchased in 2012 i believe.
the other problem is that the maintenance contract for the other licenses expired so when i phoned up to try and get some assistance they weren't interested.
regarding Luc's comment, if i have these Prime Licenses then should that automatically entitle me to install the Mathcad 15 on the same 4 machines?
(To:cwalton-2)
As far as I know, it should.
But I'm not experienced. I've never thrown money in the Prime money-pit, and as it stands it'll be long before I do.
Sucess!
Should work, but only with earlier versions of Mathcad 15.
Did you use "Reconfigure Software Licenses" option from a PTC's site? Link: http://www.ptc.com/appserver/lm/rsl/reconfig.jsp
have been looking in to it further and seems i should be able to use mathcad 15 on any of the machines that are currently running Prime 2.0........however it appears the problem is a flexnet server error.
Any of you come across this before? any ideas other than renew my maintenance contract and ask Tech support?
thanks
Do you really have a license server running locally on the very machine you are going to work with Mathcad?
Otherwise you should check your settings.
You may also set the environment variable LM_LICENSE_FILE like
set LM_LICENSE_FILE=7788@flexlm_server1.mycompany.com;7788@flexlm_server2.mycompany.com
to point Mathcad or Prime to the license server(s) you are using.
If you click yes at the message you get the license setup should come up, to give you the opportunity to tell it to use an existing license and then point it to the license file or the correct license server.
i have tried to use the option to point it to the license file but then i cant find the file to direct it to. do you know what the file path to the license file would usually be for Prime 2.0?
just FYI ... if you need to install license manager, use information available in Re: Mathcad Prime 3.0 CU license issue discussion.
MH
Martin Hanák
If you have a float license you have to set up a license server.
For single user licenses usually the file name is "license.dat". I am not sure where Prime2 would store that file per default - you would have to search for it.
