mathcad: help with Numerical Soln to Differential Eqn
hrishibhor
Please help to implement following differential equation numerical solution in mathcad
Numerical solution for single degree of freedom elastic system.
Spring stiffness = k = 2000 lbf/ft
Weight = W = 64 lbf
Force function:
F(t) = 500t+50 if t <=0.1
=-1250t+225 if 0.1 <=t<= 0.14
= 50 if t>=0.14
Acceleration function:
A(t) = ½ F(t) – 1000 *Y
Say time step = dt = 0.02
Initial Condition:
Displacement:
Y0 = 0 that is displacement is zero when t = 0
Y1 = ½ * A0 *dt^2 that is first time step which t = 0.02 this gives displacement but in terms of Acceleration at t =
Acceleration:
A0 = 0 when t = 0
Solution:
Y (t+dt) = 2 * Y (t) – Y(t-dt) + A(t) * dt^2
For t – 0 to 0.4 with dt = 0.02
Return:
Y, A
12 REPLIES 12
MikeArmstrong
(To:hrishibhor)
Please provide a worksheet.
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
attached is the mathcad sheet. This is all i could do
RichardJ
(To:hrishibhor)
Please post the worksheet in the other thread you started, where everyone has been commenting.
This is why we don't like cross posts.
this all i coul do. This is the first time i am posting question on mathcad so by mistake i have opened up another discussion in "programming...." pleas bear with me.
Here's how you might do it using Mathcad's inbuilt ode solver block (which might or might not be what you are looking for!).
Alan
Thanks for your help.
Although how would one solve it using the the numerical procedure i explained in my original post ?
The step by step solution is kind of easier to understand as to whats going. What i am not able to get right is that
dt = time step.
Y(t+dt) is in terms of a(t) (Please see the original post) so should there be loop inside a loop ?
Please bear with me i am not good at programming at all.
dt = time step.
I'll see if I can find time to look at this next week. Meantime, note that there was an error in the way I removed the units of k in my earlier file. Corrected version attached (well, corrected as far as k is concerned - who knows what other errors may still be there!!).
Alan
Appreciate that Alan.
Ok, found some time. See Example_13ptc2.
Also, corrected (yet again!) my original approach using Odesolve (see Example13_ptc1c). It's those pesky Imperial units - they get me every time!
Alan
Really appreciate your help.
Took a bit of work, but:
