Mathcad 15 will let two users open the same file without warning.
Mathcad 2001 would warn you if a file was in use by another user.
How is this even possible?
Using Mathcad 15, I receive a warning when opening a file that's already open.
File "..." is in use. It will be opened read-only.
And why not first to make a copy of the file (save it to your hard drive disk) and then quietly to work with it?
