I have MathCad 14.0 and would like to plot a 3-D polyhedral surface from a set of (x,y,z) vertices. I could not find any plotting option/function to this - am I missing something? Does MathCad 15 have this functionality?
There is nothing built-in, but if you download and install this e-book you will have more functions for plotting polyhedra than you know what to do with ![]()
I can't have that functionality because a set of vertices does not describe a surface! You would have to provide the information which vertices form an edge and which a tile. Being no 3D CAD software Mathcad's posibilities are limited and a surface is built by quadrilateralso only. But the "Amazing Images" E-Book Richard pointed you to does more most of us where aware that could be done.
In general that is of course true, but are you sure it's true when the surface is specified to be a polyhedron? If the surface is a polyhedron then I think the vertices must be on a 3D convex hull, and that is enough to determine the edges. I may well be wrong about that though, because I certainly do not have any proof ![]()
I am not sure, either, but I guess you are assuming that the polyhedron is simply connected and convex, which was not stated by the OP.
This does not mean, though, that I would know of a simple way to create the necessary data structure in MC for a convex polyhedron.![]()
Thank you all for your responses. Given the vertices one would need to do some kind of three-dimensional triangulation and then plot the faces of the polyhedron, which should be possible even if it is not concave. Alternatively, one could create a regular data grid and interpolate function values from the vertices and plot a surface. These are a couple of options in Matlab that may be a future functionality also in MathCad.
Yes, some kind of triangulation would solve the task, but you would have to provide it yourself along with the points to make for a unique solution. If only a bunch of arbitrary points in 3D space are given, there are numerous ways you can create a polyhedron with those points as vertices. No software can read your mind to determine which of the many solutions is the one you would prefer. Of course a software could chose one of the many solutions at random and create the necessary data structure to plot it and I guess it would be possible to write a Mathcad routine to do so.
Maybe the problem can be better understood in 2D. The task would be to plot a polygon when only the vertices are given. The solution is not unique again as you can see in the pics below - just 3 out of 24 ways to create a polygon with the 5 given vertices.
So a bunch of points in 2D don't define a polygon, a bunch of points in 3D don't define a polyhedron.
The situation is different if its possible to form a convex polygon/polyhedron with those points (which is very unlikely for a bunch of randomly chosen arbitrary points). Then this convex polgon/polyhedron would be the convex hull of the points and is unique.
