Dear friends,
I have problem trying to return a range from vlookup. I have a table input which defines the steel gage number against the metric thickness. The metric thickness is in column 0 and the gages in subsequent columns. This variable is named "gages"
My calculation sheet is looking at the resistance of steel walls on a silo, and can have up to 35 different thickness in the one silo. So I have a 1 x 35 input table in which the steel thickness is entered "Sidewall". This is a unitless variable, which relates to the metric thickness of the steel.
All I want to do, using the vlookup function is to return the actual steel gage numbers for each of the Sidewall thicknesses. Here is what I have entered:
wga[rn:vlookup(Sidewall[rn,gages,1) rn is the range variable 1..35
What I was hoping was to get an output wga[rn, which gives me a 1 x 35 matrix of the steel gage numbers. Instead, what I get is 35 row matrix of nested 1 x 1 matrices. However if I enter wga[3 for instance, I get the value I want.
This is most vexing! Can anyone help me get the actual value out as an array?
Frank Ward wrote:
Dear friends,
The lookup functions return a vector not a scalar, hence you get exactly what you asked for - a nested vector of vectors. All you have to do is change your expression to
wga[rn:vlookup(Sidewall[rn,gages,1)[0 <-- add "[0" to the end.
Stuart
Frank Ward wrote:
Dear friends,
Stuart
Stuart, you are a star! Thank you so much. I don't understand why it works, but am grateful that it does!
Many thanks
Frank
Many thanks
No worries, Frank. As for how it works, maybe this will help:
One thing I note is that you run your range variable from 1 to 35 rather than 0, and yet whilst the first entry in Sidewall is 0, there is a corresponding non-zero entry in gages. Do you mean for this to be the case or would your worksheet be better expressed using ORIGIN = 1 rather than ORIGIN = 0?
Stuart
