At the beginning of useing Creo elements dircet modeling 19.0 was working well.
But after a period of use, the Select (F2) command and preselect command cannot work, and the space function key is also disabled.
I don't know what the problem is.
It's solved.
Viewport setting-->Selection-->Preselection mode
