Learn About PTC’s Systems Engineering Solution
AnnMcGrath
The PTC Systems Engineering Solution combines the PTC System Requirements and Validation Solution with the functionality recently acquired (June 2014) of Atego. This brings together leading capabilities in model-based systems engineering (MBSE), requirements engineering, test/validation management, and product-line modeling. The solution helps organizations: design more innovative products using a collaborative, model-based systems engineering approach; reuse systems artifacts to enable profitable product line engineering and validate products meet requirements and best practice processes are followed. During the presentation the presenters will explores the vision, value and use cases that the solution is designed to address.
Presented by: Derek Piette, PTC
See all PTC Live Global 2015 - PTC Integrity and ALM Presentations
0 REPLIES 0
