I downloaded CREO 3.0 parametric and a few other programs included with it. I ran setup.exe and everything installed but when I try to open or run parametric it says "Missing shortcut" then it says the item "parametric.exe" has been changed or moved. How do I fix this? Do I have to uninstall and start over?
It also happened with all the other programs included. CREO direct, CREO layout, CREO options modeler, CREO simulate, CREO model checker, and CREO distributed services manager.
maybe antivirus software put exe file into quarantine ...
