I was wondering if there are any significant features of Creo that I won't be able to use with student version? I've used Creo at work as an intern for the last year, and am quite comfortable using it, but I'm now wanting to use it to work on my senior project for school at home. Just wondering if there would be any changes I need to make to my normal workflow.
I found https://apps.ptc.com/schools/references/Creo7_Comparison_Guide.pdf document. I am not sure whether information included in it is valid for Creo 10.0, too.
