I installed the academic version on a Dell M6800 laptop workstation running Windows 10. The installation was successful and the program will load. I can open a file and see the model. However, as soon as I try to perform any function, even rotating on zooming on the model the program closes with no error messages. Each time I load the program I get the same results...the program simply closes and I have no idea why.
My system is a quad core I7 with 16gb of memory and a AMD FirePro 6100 with 2gb of memory so I more than meet the system requirements. Any ideas why this is happening and what I need to do to resolve it.
Thanks.
There is problem an issue with the graphic driver for your card.
You could try the following.
In the config.pro file could you add the following line
graphics win64_gdi
If that doesn't help, could you after Creo has crashed take a look into your working directory.
There you can find std.out or even std.err.
The contents of those two files can give a better insight into why Creo crashes.
These files are erased every time you restart Creo.
Best regards,
John Bijnens
KU Leuven - Technologiecampus Diepenbeek
http://technologiecampusdiepenbeek.be/home
I would try
graphics win32_gdi
MH
graphics win64_gdi
was something one of my students claimed to have used successfully with a Microsoft Surface device.
I've just tested it and it seems you're right. This isn't supported.
graphics win32_gdi
is supported.
Best regards,
John Bijnens
Thank you for the answer. I'm a student so as not to mesh anything up can you point me to where to find config.pro? When I type this in the Explorer search window many sub directories show up.
Worked. Again thank both of you.
graphics win32_gdi
Apparently you've found the correct config.pro file.
The general config.pro file can be found in
Installation_directory\Creo 3.0\M0x0\Common Files\text\config.pro
Best regards,
John Bijnens
