Creo 3.0 Student Edition - Error Message stating incompatibility of Creo Parametric and Creo Direct Student Edition?
wtan-2
When I wanted to create a new part in Creo 3.0 student edition, there was an error message which says:
“The file C:\Program Files\PTC\Creo 3.0\M110\Common Files\templates\direct_part_solid_inlbs_rel.prt was created with a commercial version of Creo Parametric and is not compatible with the version of Creo Direct Student Edition (for educational use only) you are running.”
How do I resolve this?
Thank you!
7 REPLIES 7
Good day -
Moving this to the Academic Community to give it the right exposure.
create empty part.
rundmc
(To:MartinHanak)
What do you mean? by "Create an Empty part"?
  • File > New > Part
  • uncheck Use default template option
  • click OK
  • select Empty item
  • click OK
rundmc
(To:MartinHanak)
Hey, I tried that and still received the same error that the file "print3d_certified.conf" was created with a commercial version of Creo Parametric and is not compatible with the version of Creo Parametric Student Edition. I have never used the commericial version of Creo.
Email your request to academicsupport@ptc.com
-OR-
enter your request on http://support.ptc.com/appserver/support/academic_case_logger/academic_case_logger.jsp
rundmc
(To:wtan-2)
Was this ever resolved?
