Creo 3.0 Student Premium?
cwatson
Hi all
I've just downloaded (for £185ish) the student premium version of Creo 3.0, but it doesn't seem to offer either the NC milling or injection moulding processes that I actually need for uni. I'm curious if it's maybe just an error I've made during installation or if it actually doesn't offer 80% of the functionality that students need?
Thanks for any help...
Calum
if you go to PTC Webstore and activate Key features tab, then you will see contents of the Premium license. NC manufacturing and Mold is not present.
MH
9 REPLIES 9
did you check your license file, if it contains needed modules. Please publish picture of contents of your license file.
MH
Thanks for the quick reply Martin
I'm not really sure what to look for, but this is what's in the downloaded file:
If you can point me in the right direction I'll have a look for whatever you need to know...
For example we need the mold cavity option which is grayed out here, which is basically an entire module for uni which I can't do at home:
Thanks again
Calum
1st picture ... installation media
2nd picture ... File > New dialog box
None of pictures contain licensing information. I guess that you received license file via email. The file is somewhere on your disc, its name is something like *license.dat.
To see modules included in your license, you can click File > Help > System information and scroll the output (this sequence is valid for Creo 2.0). You will see something like this:
MH
Hi Martin
Here's what the license says:
It does say Education Edition, which I though was different to the Academic version? So when I bought Student Premium I hoped it would be a full program, the sales woman said she didn't know either but if it has to be paid for it's usually a short term full version. Or where it says License Name: CREOPMA_StudentP3 does that mean Student Premium?
I'm guessing then I need MOLD_ANALYSIS full and also whatever the CNC functions are called?
Thanks again
Calum
look at the following picture...
The picture says that your installation uses two license files located in C:\ProgramData\PTC\Licensing directory.
Please open them in Notepad, we need to locate lines beginning with INCREMENT keyword.
Maybe BW*license.dat contains Premium license. If this is true then you will need to modify parametric.psf file to use info from this file.
Two important lines in parametric.psf file are:
ENV=PTC_D_LICENSE_FILE-=path_to_licence_file
ENV=CREOPMA_FEATURE_NAME=Creo_License_name ()
MH
Hi Martin, I hadn't realized you'd replied already so I'm sorry for the delay!
These are all the INCREMENT bits I can see, the first 3 are from the BK*license.dat and the rest from BW*license.dat.
INCREMENT CREOPMA_Student3 ptc_d 34.0 20-oct-2016 uncounted \
  10C060B05D7866B8D52F VENDOR_STRING="VSVER=2.0 \
  LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,110,115,127,128,135,137,155,188,191,283,325,326,336,347)" \
  HOSTID=PTC_HOSTID=14-DD-A9-55-96-2F SUPERSEDE \
  ISSUER=PTC-WEB-CREOSTUDENT3 ISSUED=21-OCT-2015 \
  NOTICE="b00260255@studentmail.uws.ac.uk, " \
  SIGN2="1EE7 AC07 E709 8F94 598B 5A6D F471 8290 A42C \
  FC67 5841 C0CC 6724 20F9 F639 1E8F E6A1 6F89 C711 \
  07DA 4EE1 7D39 5559 90F0 2D66 C87A 32F4 BB1C 4F18 \
  7441"
INCREMENT CREOLAY_Student3 ptc_d 34.0 20-oct-2016 uncounted \
  0080F0B050297775B23E VENDOR_STRING="VSVER=2.0 \
  LO=(6,7,17,19,32,69,110,291,326,336)" \
  SIGN2="1D6D 5DB4 FA9E D555 DFB8 7CB9 1D7D 0590 C8E6 \
  13AC 8ADD CA4F 5544 AB12 1CB9 0DEE 2015 8C49 4B52 \
  40C8 D2B8 DA0D EFBA A330 22BD 0AC5 0762 6ABF CEBD \
  9D0E"
INCREMENT CREODMA_Student3 ptc_d 34.0 20-oct-2016 uncounted \
  D0D03010A5F80FC1957A VENDOR_STRING="VSVER=2.0 \
  LO=(6,7,17,19,32,69,110,155,326,336)" \
  SIGN2="1B16 F2F6 149D C822 B026 32FE A84F BE64 DF58 \
  2689 84E7 9030 19DF 4516 ABA8 0445 5BE7 4AB4 38B1 \
  7E46 FADA FF55 BA64 CCC2 7592 9A10 6894 CEC2 FC4E \
  488C"
INCREMENT MECBASICUI_Academic3 ptc_d 34.0 26-oct-2017 \
  uncounted 50D0E03020362587981A \
  VENDOR_STRING="VSVER=2.0 LO=(19,136,211)" \
  ISSUER=PTC-WEB-CREOACADEMIC3 ISSUED=26-OCT-2016 \
  SIGN2="0506 326D D28B 7774 D1A7 59D6 E29D A3AC 822B \
  8111 2D71 A636 D115 BD36 CB86 0AD5 43D1 D7C0 E162 \
  5461 D13A BE71 2FB8 2FAD EA70 96DB C3BB 5BE9 31BA \
  4288"
INCREMENT CREODMA_StudentP3 ptc_d 34.0 26-oct-2017 \
  uncounted E030F070A20667016A6C \
  LO=(6,7,17,19,32,69,136,155,326,336)" \
  SIGN2="1DFE 86FC E665 5C27 DC31 2302 E209 50AB D7C1 \
  487C C750 4A3A B32B 5662 B4E2 017B 023A 08B3 FC4C \
  4BE9 63CA 7356 4701 2334 4FD7 F10D B71E E9F8 5105 \
  CE31"
INCREMENT CREOLAY_StudentP3 ptc_d 34.0 26-oct-2017 \
  uncounted 0080D070B561C37CAE26 \
  LO=(6,7,17,19,32,69,136,291,326,336)" \
  SIGN2="097B 4EB0 8658 5F1D A6D1 26E7 6BF9 C703 43F9 \
  E2C0 D31B 867C EF5C 9316 5F78 0380 BED3 6666 C5AD \
  2033 16D9 25FD 7162 E8AB B8F1 91BC D8ED 2717 2D7E \
  2E8C"
INCREMENT MECBASICENG_Academic3 ptc_d 34.0 26-oct-2017 \
  uncounted 70404020CC48FF04A85D \
  VENDOR_STRING="VSVER=2.0 LO=(19,212)" \
  SIGN2="0344 FD57 7B17 772E 5575 A307 EE29 0DFD E824 \
  F0C3 B242 F9ED 2B1E 071F 4634 1CC7 3C23 A991 97A3 \
  D187 5B2A DC16 28CB 7337 C9CD 081A B88D 4344 0FC4 \
  EF64"
INCREMENT CREOPMA_StudentP3 ptc_d 34.0 26-oct-2017 \
  uncounted 1070307014AE7F9067B4 \
  LO=(0,6,7,10,17,19,32,34,40,45,48,51,61,63,66,69,71,73,97,106,115,127,128,136,137,155,158,188,191,275,277,278,283,325,326,336,347)" \
  SIGN2="1DED 3647 34A3 D364 6D9F BC3E 5D10 C092 FAAE \
  0B53 9285 792B 32F5 A8D1 CA24 031D 7B40 7761 EDAE \
  94F6 CB5F 7EAB 478C E268 5920 4B97 3BDC FA08 B537 \
  ABA0"
Where would I find parametric.psf? Even a search doesn't bring that file up???
Thanks again
Calum
1.]
BK*license.dat is not valid any more, because licenses expired on 20-oct-2016
2.]
BW*license.dat licenses are valid until 26-oct-2017
3.]
parametric.psf is located in C:\Program Files\PTC\Creo 3.0\Mxxx\Parametric\bin directory by default (I hope)
4.]
Your parametric.psf file should contain:
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BW400503ED1165-QFHV-DRRX_license.dat
ENV=CREOPMA_FEATURE_NAME=CREOPMA_StudentP3 ()
5.]
CREOPMA_StudentP3 license contains following modules
You can find translation of numbers into names in license.res file located in C:\Program Files\PTC\Creo 3.0\Mxxx\Common Files\text\licensing directory
Instead of looking into this file, you can click File > Help > System information
MH
MH
Hi Martin
Disappointing that the $200 student premium version of the software doesn't allow for 75% of the work we need at university!
Thanks for all your help though.
Calum
