Creo 5.0 Premium Edition Standalone Educator CFD licence
mtepermeister
Hi, I just installed the Creo 5.0 Premium Edition Standalone Educator edition of Creo in order to help mentor my FRC robotics team. I was excited to try out the new simulate capabilities. When I installed, I went into the "application feature" section of the installer, and saw that "Creo Flow Analysis" and "Creo Topology Optimization" were unchecked. I checked their boxes and continued installing.
Now, Creo simulate appears to work well, and topology optimization opens as well! Unfortunately, when I click "Flow Analysis", it tells me that "The selected functionality requires CFD Analysis License".
When I go to file->options->licensing, and click Refresh license list, I see an optional floating license called CFD_ADVANCED_PLUS_SET. If I select this floating module, it says that it's been activated, but still won't let me open flow analysis. It says:
Option CFD_BASIC not ordered, please contact your sales representative.
Option CFD_ADVANCE not ordered, please contact your sales representative.
Option CFD_ADVANCE_PLUS not ordered, please contact your sales representative.
What should I do? Is flow analysis actually included with the premium educator license?
Thanks so much,
~Max
15 REPLIES 15
CFD is not working yet in any product code based license.
We are working on this, but sadly I can't tell you when it will be available.
Alex
Hey, Is there any update about whether this is possible now?
Thanks for your time!
~Max
Hi, i got the same issue whereby a CFD license is need for flow analysis. how do I resolve this issue?
Was this ever solved? I’m having the same problem
open parametric.psf file in Notepad (path example ... E:\PTC\Creo5_040\Creo 5.0.4.0\Parametric\bin).
Check line starting with ... ENV=CREOPMA_FEATURE_NAME=
Add 10131 into parentheses.
The line should look like ... ENV=CREOPMA_FEATURE_NAME=PROE_some-name (10131)
Note:
  • 10131 is code number of CFD_ADVANCED_PLUS_SET
Martin Hanák
I did that and when I restarted creo I got the error: "Features Not Obtained: CFD_ADVANCED_PLUS_SET"
DS_9781704
(To:DS_9781704)
Hi, does anyone know why im getting this error?
Hi @MartinHanak
Thanks for the suggestion. I just tried this on my linux installation through wine and it didn't work. Still complains that
You have not checked out the license option. Please click "File->Options->Licensing" and choose required option from "Refresh license list".
When I go into File->Options->Licensing I have the same problem as before. I can see the CFD_ADVANCED_PLUS_SET license, but checking it doesn't do anything. The error messages in the console seem to imply that creo is looking for CFD_BASIC, CFD_ADVANCE, and CFD_ADVANCE_PLUS, but not CFD_ADVANCED_PLUS_SET.
I'll try on my windows installation later if that'd be helpful. Though DS_9781704 seems to be having a similar problem. I don't see that Features Not Obtained error though.
~Max
Note that I tried this on a creo 7.0.2.0 Installation.
If I need to go back to 5.0, then I can also try that later. I think my license for that version might be expired though.
if I could view your license file, I could tell you what's in it ...
Martin Hanák
Is that something that I should just post online?
it does contain the lines:
######### Super-Module Bundle 10131 Definition ##########
# Creo Parametric Node Locked Option
#Feature Line Type = INCREMENT
#Feature Name = PROBUNDLE_10131
#Feature Version = 38.0
#Version = Creo 7.0
#Number of Copies = uncounted locked modules
#Supercede = Y
#Issue Date = 08-SEP-2020
#Expiration Date = 09-SEP-2022
#Node Locked Option = Creo Flow Analysis
#Node Locked Option = Creo Flow Analysis Plus
#Node Locked Option = Creo Flow Analysis Premium
Let me know if there's anything else I should look for or if it's safe to post somewhere/if I should redact anything when posted.
Thanks!
~Max
#Version = Creo 7.0
#Supercede = Y
Thanks!
~Max
I think you know that you posted comments, only. It would be better if I can see the whole license file. You can send it to m h a n a k @ c o g r a s . c z (remove spaces).
Also please upload/send your parametric.psf file.
Martin Hanák
Hello was this ever solved?
