Hello. I long time ago i set my default working directory using shortcut/properties/start in. It worked fine until today. When i start a new part creo will use my config file that is saved in my working directory, however, when i go to save the part i have to navigate to my working directory. Until recently when i would click save the window was already opened in my working directory. I tried reentering the command in "start in" but that doesnt fix it. Its weird because when i first launch creo and select working directory it automatically brings up my working directory. I never had to do this extra step before.Any ideas?
