Creo Parametric 10.0.0.0 Not working
HS_10968421
2-Guest
https://www.mediafire.com/file/x5s78y2pvnhy7hz/LiftingTable3STEP.zip/file
I'm trying to open these files, but they wont open.
  • I downloaded LiftingTable3STEP.zip
  • I unzipped LiftingTable3STEP.zip
  • I started Creo 10.0.3.0 and opened Assembly1.stp
Martin Hanák
