Helical Sweeps
Hi, just wondering if anyone can help with a complex helical sweep one of my students would like to create? The student has produced a helical sweep to represent a round bar and would now like to add a spring over the top of the bar (to wrap around it) so it follows the same shape. In other words they would like to produce a helical sweep around a helical sweep. Does that make sense and is this possible? Attached is a jpeg of the sweep the spring would need to wind around.
You might like to look here for some help
Thank you both for your help on this issue, I'm going to have a play this weekend. I'll let you know how it goes.
