Help license error
jeanclaudeHartm
Help license error
Good night by installing news license j 'ai the following message d 'erreur "invalid license syntax" which can m 'aider? Merci
I believe you get that error when the host ID is not correct.
is this a laptop or a desktop? does it have more than one network cards?
I have the same problem and i have a laptop what should i do??
