Help regarding Navigating among mashups without navigation link
sred
I need a help regaridng navigating among mashups
1. i have four mashups
first mash up have three guages ( temperature, humidity, pressure)
second mash up is temperature graphical representation
third mash up is humidity graphical rep
fourth mash up us pressure graphical rep
How can i go from first mash up to second mash up (temoerature ) if i click on guage  with temperature in first mash up (guage doesnt support navigation) and vice versa
Aanjan
9-Granite
(To:sred)
Sin, you can still use the Navigation widget - set/ check the 'Transparent' property on the Navigation widget and move that onto the top of the Gauge widget (expand the widget to match the gauge's size if needed).
emoreira
(To:Aanjan)
Sin,
Adding to Aanjan Response: you will need either to add a panel before  you add the Gauge as you won't be able to add the Navigation Widget on a responsive panel.
You can also use the Frame widget (available in the MarketPlace). Unfortunately this widget did not work in TWX 7.2, but I tried on 6.x version and it worked.
Ewerton
