If you are getting a 404 Error...
StacieKaufman
Hi everyone-
If you are trying to download PTC Creo 3.0 for universities and are getting a 404 error, the link has now been fixed! If you re-register, you will be taken to the Thank You page where the PDF link has been corrected.
Please let us know if for some reason you are still getting the same error.
We're very sorry for the inconvenience,
Stacie
I would recommend clearing your browser's history, then trying the link below:
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
Chris
I keep having the same error, I need the license to install the student version of PTC creo 3.0, the link hasn't fixed yet.
I keep having the same mistake too , I need the license to install the student version of PTC creo 3.0, the link hasn't fixed yet.
i haveing the same problem to install this version.
Can you fix it now or send me the correct link.?! thanks
Chris
