i installed Creo2 Academic on my Workstation at home. The Installation worked well and the product key was okay also.
When i try to start Creo now, there appears a "Message" Window for like one seconde, and nothing happens.
I tried to start it as admin, tried to run it direct from the .bin Folder, deinstalled it and did a new Installation - same error.
See attached in the Video. This is the message that appears, then nothing happens.
I hope u can help me
locate config.pro file in Creo installation, open it in Wordpad and add following line at the end of file, save, test Creo start:
graphics win32_gdi
Path to my config.pro ... C:\PTC\Creo2_M070\Creo 2.0\Common Files\M070\text\config.pro
MH
Did´nt worked
