Hi!
I just downloaded the student version of Creo 3.0 to my windows 10 laptop and when I go to try and open parametric it gives me a warning message that the license request failed for the feature? I went through the given set of instructions to set up the program and the license code I was given was approved so I'm not sure where to go from here. Any help would be awesome.
Thank You!
