Problem with starting CREO
JKK
During start of Creo pops up a message window:
License request failed for feature
Requesting CREOPMA_Student2 ...
C:\ProgramData\PTC\Licensing\BK390206EDSTUDENTUNICL_license.dat: (-10) Feature has expired.
I am using Creo Parametric 2.0, windows 7, I just updated Adobe Flash.
I had not been using Creo Student license for some time, I was not aware of any expiry of student licenses.
Thank you !
MartinHanak
24-Ruby II
(To:JKK)
open C:\ProgramData\PTC\Licensing\BK390206EDSTUDENTUNICL_license.dat in Notepad and check expiration date. Student license file contains a line similar to:
INCREMENT CREOPMA_Student2 ptc_d 33.0 23-may-2014 uncounted \
Student license is valid 1-year starting from its installation.
I guess you have to uninstall Creo 2.0, remove license file and install it again.
Martin Hanak
Martin Hanák
MartinHanak
24-Ruby II
(To:JKK)
Martin Hanak
Martin Hanák
I have the same problem... On this page "http://support.ptc.com/products/proe/studentedFAQ1.htm" says that student license does not expire (here:
Does the Student Edition have an expiration date that disables its use after a period of time?
No. The Creo Elements/Pro Student Edition is a perpetual edition. It does not expire after registration."
Is it a joke? Why do I have an "expiration date" in my license file? How can I reinstall it if the expiration date in license file is December 4, 2014?
Thank you for your time and support.
Mihai
I've moved this discussion into our community.
Mihai,
you have to ask PTC to send you license file for next year. When you receive it, you simply put new contents into the current license file.
Martin Hanak
Martin Hanák
