Problems installing creo 3.0
ffilho
When I try to install creo 3.0 all but the common files are unsuccessful to install.
Next when I press the finish button, nothing appears to execute the program.
How should I proceed?
find some fellow student who already installed Creo successfully .
Remove remnant of unsuccessful Creo installation. Then go to https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp (you have to login), download Creo 3.0 zip file (I hope that your Windows are 64-bit), unzip it and run setup.exe
MH
Martin Hanák
Maybe there is a hint in the PTC Install Manager (PIM) install log at %userprofile%\Documents\pim_installmgr.log
