Put multiple data in one request
aalbot
     Hi, I'm using http rest API by ArduinoYun. The question is, I want to send mutiple data to thingworx in one request. For example, I want to send temperautre and humidity to thongworx, now I use two request such as
curl http://zucc.cloud.thingworx.com:80/Thingworx/Things/DHT21Thing/Properties/Temperature?appKey=deaf648e-e691-4e9e-88a9-1a8…
curl http://zucc.cloud.thingworx.com:80/Thingworx/Things/DHT21Thing/Properties/Humidity?appKey=deaf648e-e691-4e9e-88a9-1a80b21145c3&method=put&value=66
I think maybe it could be zipped. Am i right?
PaiChung
22-Sapphire I
(To:aalbot)
You can use a PUT to send multiple values, with the Values object defined as a JSON.
Here is the article that outlines it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS211045&art_lang=en&posno=8&q=rest%20api&ProductFamily=ThingWo…
PaiChung
22-Sapphire I
(To:aalbot)
Hi Pai,
Like this?
curl "http://zucc.cloud.thingworx.com:80/Thingworx/Things/DHT21Thing/Properties/*?appKey=deaf648e-e691-4e9e-88a9-1a80b21145c3" -X PUT -i -H "Content-Type:application/json" -H "Accept:application/json" -d '{"Temperature" : 44, "Humidity" : 44}'
Thankyou,
Angel
sv
(To:aalbot)
U can use put method
eg:
1. Use a property called: "test"
2. Set the property as "23|66" that is temp=23 and Hum=66
3. Then write a service called "Logservice" for splitting this pipped value
URL:
http://zucc.cloud.thingworx.com:80/Thingworx/Things/DHT21Thing/Properties/test?appKey=deaf648e-e691-4e9e-88a9-1a80b21145c3&method=put&value=23|66
and fire the Service URL
http://zucc.cloud.thingworx.com:80/Thingworx/Things/DHT21Thing/Services/logservice?appKey=deaf648e-e691-4e9e-88a9-1a80b21145c3&method=post
