Simulation License for Students
TH_10154594
Hi everyone,
Is it possible to have CREO simulate licenses for the student version? I want to do some fluid analysis of a cold plate, but my version says I need the correct license to do so.
I am running Creo 9.0
I think information available in https://community.ptc.com/t5/PTC-Education-Forum/Creo-Simulate-license-error/m-p/236056 is still valid.
Martin Hanák
Hej, I have the same issue, in Creo 3 I could use the "simple" FEM module, now I am with Creo 6.0 for educators and I can neither start new simulations nor open the old results. Is there a workaround? Would be extremely usefull.
Best
Tim
Hi Tim,
No- unfortunately, the later student versions of CREO simply don't include any simulation packages and they can't be added in. Although I can't confirm if you can purchase it to add on.
It's a bit of a shame really.
Best of luck!
Thomas
Hi Thomas,
thanks for the quick reply. That is very unfortunate, It must have been possible somewhen in the past! I guess I need to get the Ansys Student Software for simulation then, kind of hazzle for only a simple FEM but OK, you get what you pay for:)
Best
Tim
