Hello,i instlled creo 3.0 student edition and when i made model i went to assembly to made animation and when i click on ,,Mechanism,, creo give me:Startup of application "MECHANISM" failed.I really dont know where is the problem,i reinstlled few times
Did you specifically install Mechanism when installing the software?
This actually has to be selected in order to install. Had the same issue when I 1st installed Creo.
i think i correcttly installed,how can i cpecifically install mechanism?i dont have this option,i have just for creo parametric,stimulate,layout and others...Thanks
This option is under a different window. You should be able to go back in and add Mechanism. It will appear as it is doing a re-install but it should only install the mechanism link to the license. Do not uncheck any of the other things installed already... it -will- uninstall them
I am not an installation guru, so I can only point you in the right direction. I get hives just thinking about updating Creo
See here: Has the Mechanism Extension been un-bundeld from Creo?
INFO: Mechanism Design is installed automatically during CR3 installation. Creo license file must contain Mechanism Design License (code 127) to enable user to use its functionality.
Unfortunatelly I have never seen Startup of application "MECHANISM" error message, therefore I do not know why it is displayed ...
Thanks Martin. I was not aware that they toggled the default in Creo 3. It's been a while since I installed it.
Andrej, you can fill out a support form if nothing else works for you.
Try to use "Academic Support Request" from PTC:
Usual questions - what Operating system, what computer maker, what graphics card?
