Folks,
Disclaimer : I don't yet have an installed PTC Navigate instance, so this is coming out of imagination.
As I read from PTC Navigate User's Manual, we are required to setup separate instances for Windchill Server & ThingWorx.
I was wondering if both can connect to same Corporate LDAP being used across a company.
Also, can we set different roles for same Corporate LDAP user, in Windchill & ThingWorx resp. ?
~SiD
If Navigate is using the ThingWorx Windchill Extension, you normally configure this so that ThingWorx uses the Windchill LDAP to perform authentication.
See section around p29 of http://support.ptc.com/WCMS/files/164699/en/WCTWXExtension.pdf for details.
Thanks for your answer & attached document.
I hope to have an instance early next week where I can try out this configuration.
~SiD
