Cant build package with "mvn package"
I am having the same issue when I try maven on the Raspberry Pi itself. When I run maven on Mac OS X, the error does not happen.
The error I see on the Pi is:
[ERROR] Failed to execute goal on project temperature-thing: Could not resolve dependencies for project com.ptcmanaged.thingworx:temperature-thing:jar:1.0-SNAPSHOT: Failed to collect dependencies at com.thingworxs:thingworx-common:jar:5.0.0: Failed to read artifact descriptor for com.thingworxs:thingworx-common:jar:5.0.0: Could not transfer artifact com.thingworxs:thingworx-common:pom:5.0.0 from/to ptc-managed-services-public (http://maker01.cloud.thingworx.com/mvnrepo): maker01.cloud.thingworx.com: Unknown host maker01.cloud.thingworx.com
Appreciate some help here.
In this thread:
How to resolve the problem of apache-maven
I found out about manually installing the missing file -- see Stephen Harmon's reply
I found on ThingWorx MarketPlace, the Protocol Adapter SDK and the zip file you can download there has the missing jar file:
thingworx-common-5.4.0.b445.jar
in it.
I then edited and executed the install-thingworx-jar.sh script to insert the jar in my .m2 local repo.
After that the mvn package worked on the Pi itself to create the jar that feeds data from the AM2302 sensor connected to the Pi up to the ThingWorx academic cloud.
Thanks for the info.. Took a long time to figure it out.
Now solved..
Can anyome manage to complete this project?
