is the pattern feature disabled in academic version?
jfoy
I just downloaded and installed Creo 3 Academic and I can't seem to use the hole or pattern feature. I have some experience with SolidWorks and the overall operation seems to be very similar. Just doodling around I created a basic extrusion then tried to use hole tool. From the hole tool pane, I can't get the option to accept the hole. I then tried to use the pattern tool and it will not allow me to select a sketch to repeat or change the number of items in the pattern. Am I doing something wrong or are these features not included in Academic?
0 REPLIES 0
