license request failed for feature
jfranco
After finally installing Creo 3.0 Student Version , 64 bit, I am getting error (in std.out file):
License request failed for feature
ERROR - C:\Program Files\PTC\Creo 3.0\M030\Common Files\text\config.pro, linenum 5 : Keyword 'ALLOW_SAVE_FAILED_MODELS' is not valid.
Please help. Installation has not been easy!!!
I am having the same problem. Have you been able to find a solution?
