PTC eSupport Help FAQ
Pierre_M
  • I'm new to eSupport Portal. Where do I start ?
  • I'd like to suggest an enhancement to the eSupport Portal or one of the tools. Who should I talk to?
Product ideas are the right channel to propose a change to the eSupport team. Check if your idea ha snot already been submitted. If not, create a new idea and other customers will comment on your proposal.The eSupport Portal team will review and comment on the most popular ones.
  • I can't find anything in the Knowledge Base. What's wrong?
We're sorry to hear this. Let's see how we can  help you out
    • If our search engine is returning too much content, try to use one of our advanced search techniques to narrow down the number of results returned
    • If  our search engine is returning too few results,
    • we don't have content for this specific topic and you should start a discussion to talk about
  • I have a problem with one of the eSupport Portal tools. How do I get Help?
Right here in our discussion forum!
    • Some tools might not work well on some browsers or mobile devices.Try again in a different browser
    • If it still does not work, check the discussion forum to see if someone already reported the same issue and got a solution.
    • If it's not the case, report the issue in the forum
  • I connected today and things are different, what happened?
We usually update the eSupport Portal on a monthly basis. All changes are recorded in our release notes article and the most significant ones are detailed in the blog.
0 REPLIES 0
