I've been using Schematic for about 3 months now....slowly getting acclimated.
I want to learn how to use the circuit diagram feature of Schematic, but the overall support for this very lacking.
Does anyone have a guide that they have used for this?
Some of the things that I would like to learn:
Thank you
you can find info about CID/WID in the help center topic About Creating a CID to WID Design .
in CID/WID design you need to set the following :
in this example , Creo Schematics will look for mate connector which have the value defined in mates_with (in the component) in parameter part_number (in the connector)
Creating WID from CID :
read topic About Placing Component Wiring Shapes and the topics following it .
Gaby
Consider joining the "tech committee" for routed systems. We have monthly peer to peer discussions among the users.
https://ptcusergroups.ptcuser.org/organizations/category/Technical%20Committee/page/2?order=name.asc
If you build your circuit components with WID at the type and attach connectors to them. You can create your design completely there with only one diagram needed. People call it a hybrid design.
Instead of a CID that is signal based, it is wire based (you can use a property to give the wires signal names).
People who have to trace the circuit can do it easier but it adds lines the the drawing, especially with ground wires that are drawn as one line on a CID but now have all the individual wires shown.
By judicious use of "extend across sheets" or data highways, you can hide the lines for larger networks. The extend across sheets is a poor name, you can use it on the same sheet also.
