Using 6.0.1.0 and AFX and it has never worked. And the suggestions all tell me that the two applications are not compatible. with the number of possible reasons for failure and the convoluted workarounds I am officially considering this beta testing without consent. I did learn (by accident) that you can run an analysis on the sketch without the solid model. Yay! success... Not so much. endless cryptic errors. and it seems impossible to select individual members to define the section properties and the the endless Y axis error. I have given up and am using a freeware solution from the web. so much for this high end software.
