Hi i have a problem with config.win
In Creo config.win was replaced by "creo_parametric_customization.ui" it is right but I have a lot of icons to launch the mapkey defined in wf5.
My question is :
I can recover these icons in "creo_parametric_customization.ui" and hope they work ?
Thanks to anyone i want to answer
you can, but it is a bit tedious. This is how I got it to work.
You will first need to put your mapkeys in the ribbon (customized) in Creo. The default icons will be smileys.
I had to have two sessions up, one WF4 and one Creo2
In WF4, I went to the customize screen section and copied the button to the clipboard, then went to the C2 and pasted the button image on the mapkey in the customized ribbon. Repeat for each icon.
Hi Stefano,
Ron is correct. It is a bit of a tedious task, but that is what you will need to do, to get your mapkey icons into Creo.
Amit
The other solution is to just re-create them....
Ron
