Auto-Preselect on Tabbing through dialogs
cpipe
3-Newcomer
I am using Creo Elements/Pro 5.0 M120 and have a question about the dialog boxes. Is there a way to configure this version to aout-preselect the contents of a cell in the dialog boxes when you tab into the cell?
For example, when I start a new part I like to complete as many of our parameters as are known and would like to just tab through the parameter list (see screen shot) and continue typing. Since my current "config" doesn't preselect the contents of each cell, I have to grab my mouse and drag or double-click the cell to highlight its default contents before I start to enter any new information. This process is slow and annoying to me.
[Description: cid:image002.jpg@01CD23C6.3D018920]
Thanks!
Chris J Pipe
Engineering Systems Analyst
trans-matic
300 East 48th St.
Holland, MI 49423
phone (616) 820-2537
www.transmatic.com
cpipe
3-Newcomer
(To:cpipe)
Well, here's the best (and only) feedback on this. I would consider this a work-around, but it does keep the hands on the keyboard which might be a little faster.
May not be the best option but - once you tab into the cell you can hold the shift key and puss the end button (or home button, if at the end of the text string) That will highlight the contents...then just delete or type new info.
Once it's selected or highlighted; you can also do (Shift + F10) that's the same as right click and will bring up the copy/past menu if you need to.
All without using the mouse.
Thanks Tracy.
Chris Pipe<">mailto:->
Eng. Sys. Analyst
trans-matic
NEW Creo+ Topics: PTC Control Center and Creo+ Portal
