Autocad DWG files problems (GMT toll and turkish fonts)
MarcoLoli
Hello to everybody, I'm having some problems using PV standard trying to visualize Autocad files with turkish font and geometrical tolls. Fonts and geometrical symbols are automatically substitute with "strange" caracters. Could you please suggest some PV config. files that I can use to work on. Another problem is related to line widht, not able to set those properly. Thanks Marco
MarcoLoli
(To:MarcoLoli)
Solved! You have to add the SHX file that the Autocad user have in their PC.
