Dear all,
Recently I have switched over to Creo 2.0 from Proe WF 4.0.
I am placing BoM balloons in the drawing for very large assembly with simp reps.
I keep all balloons lines vertical and save the drawing.
When I open drawing again at that time all balloons get scattered. I donot know whether it is becuase of any change in assembly or it has to do something with config file.
Thanks.
Vimlesh
You might see if it is due to an explode state being active in the assembly. I have seen some weird things happened with the explode state active even if the view has nothing to do with it.
I would also recommend capturing your situation and forwarding it as a support case. Just save a file set and a process where this is easily repeatable. You can then submit the files and process to show what is happening.
