Browser Homepage
cspinelli
Browser Homepage
hello,
i have a problem with browser embedded in Creo 3.0; even if i change web_browser_homepage to about:blank in config.pro, when i open Creo it shows a second homepage with www.ptc.com/community
do you think i can solve this problem and show only one homepage?
thanks
StephenW
23-Emerald II
(To:cspinelli)
Add these config.pro options.
web_browser_homepage about:blank
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab no
enable_resource_browser_tab no
I know how to remove all the browsers; would that help?
cspinelli
(To:MadhaviG)
Maybe ican try to see if it works
1. Please find details in attached file "Capture.png"  (Uncheck the makred check box.)
2.  if you set
web_browser_homepage -> about:blank
enable_3dmodelspace_browser_tab  -> no
then you end up having two browsers. Result is in "Capture2.png"
3. Another option: I did not find way to reduce the number of browsers but by updating few html files we can set all browsers to about:blank.
I hope all this information helps you!
Madhavi
cspinelli
(To:MadhaviG)
thanks
StephenW
23-Emerald II
(To:cspinelli)
