for many years I'm using Creo Elements Direct Modeling Express 6.0. Some weeks
ago I installed Creo Elements Direct Modeling Express 8.0 on my Windows 7 pro.
Once Creo Elements 8.0 is runnung with a opened pk2-file and I want to add another
pk2-file from the Microsoft Explorer by clicking on it, then Creo Elements 8.0 the
pk2-file opens in a new instance and a second prozess is runnig.
Is there any setting for Creo Elements Direct Modeling Express 8.0 in which this
behaviour can be changed?
I do not know if it is possible. I use drag and drop, which works fine.
thank you.
in my case this method is working too.
But this way is for me not very comfortable.
I would like to make something in the settings.
If this is not possible I will return to Creo Elements Direct Modeling Express 6.0.
