CREO 2.0 Mechanism Design Module License
aa-5
Hi all,
I am using CREO 2.0 parametric.And I am using FLEXLicensing. I tried to use spring option in mechanism Design Module, but I couldn't find the spring option in the module other than options such as CAMS, GEARS, SERVO MOTORS etc.I checked with my IT team regarding this, they are helpless.I checked the Licensing in CREO, the list shows 80 Mechanism design licenses are free.  Rquest your support to acquire the license for mechanism design.
If there is no solution for that, please let me know academic version available in the website have Mechanism Design Module with spring option ready to use.
Arun.A
TomD.inPDX
17-Peridot
(To:aa-5)
There is a mechanism dynamics option.
This adds capabilities to the included mechanism module.
They really should have made the menu compatible with only your installed modules.
Much of the optional extension includes much greater analysis capabilities.
MartinHanak
24-Ruby II
(To:aa-5)
see my answer in Creo Parametric and Mechanism Design
Hi Marin,
Please share the procedure to add MDO module in CREO 2.0.
Arun. A
MartinHanak
24-Ruby II
(To:aa-5)
launch ptcstatus and look for Mechanism_Dynamics item. If it is present, then go to Creo2_LOADPOINT\Creo 2.0\Parametric\bin and open parametric.psf file in Notepad.
Add 191 code between parenthesis, see following example ...
ENV=CREOPMA_FEATURE_NAME=PROE_FoundationAdv (191)
gkoch
(To:aa-5)
Hello Arun,
did you succeed following Martin's hints?
If yes, please follow-up by marking his answer as Correct Answer. This will signal to other users that the question has been answered.
Gunter
