For ModelCHECK in Creo 9 (or 10) is it possible to only run the checks on models which are not Locked? If the Windchill status is unlocked then I'd like to run ModelCHECK. I know I can configure the condition.mcc file to key in on parameters like PTC_MODIFIED and PTC_WM_LIFECYCLE_STATE. But these miss many use cases. Filtering on read only status would fit our workflow better. Maybe there is a hidden parameter value which can be accessed by the condition.mcc file?
Hi N.Barnes,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
This will increase your chances to receive meaningful help from other Community members.
Anurag
