Cant Open Creo after installing. LoadLibrary failed.
ptc-4340771
1-Visitor
I installed Creo Elements Pro School Edition on my computer. Everything works fine during the installation but every time I try to run the Programm an error is displayed. "LoadLibrary failed. Error 998. Unable to access memory" (or sth similar, translated from the german error display) I tried a lot with the help of my prof but nothing seems to work. Now I cant install Creo Elements Pro School Edition anymore because I used the maximum amount of licences. I wrote to the support Team and haven't received a reply yet. Even if I can install the programm again I might not be able to run it.
all my computer details can be found in this text document http://www.mediafire.com/?bb8880ycsaxm1c7 or on the document attached to this post.
Does anyone have a similar problem and solved it?
Help would be highly appreciated.
Kind regards
Dennis
Hello!
On the computer it is installed "ATI Catalyst Center" (the program for resource management of ATI video adapter) and what version?
Hi VladimirN.
Its the version 2009.0918.2132.36825
Kind regards.
Dennis
Try to upgrade to the latest version: http://support.amd.com/us/gpudownload/Pages/index.aspx
wow it actually worked!! Thank you so much! i spent hours and hours on the internet, searching for a solution!
Thank you vladimirN.
You're welcome.
NEW Creo+ Topics: PTC Control Center and Creo+ Portal
