Does anyone know how, in a command prompt, to remove the last character in each line of a .txt file?
I need to open a family table instance, do one operation, close that instance then open the next instance and do the same thing. And so on.
I am combining a mapkey with a batch file and I am close. But I have to remove the last character in each line and I can't figure out how.
I saved each page out as an .mht file; hopefully you can read them.
Steve,
you can do following (for example):
1.] install sed (stream editor) ... available at sed for Windows
2.] use command prompt command ... sed "s/.$//" a.txt > b.txt
a.txt ... source file
b.txt ... removed last character in each line
MH
You don't have to install external sfotware. You might be able to do this with a batch, but vbs has a little more utility. In your config.pro, just change the .bat to .vbs and use the code below (with modifications as required)
Set objFS = CreateObject("Scripting.FileSystemObject")
strFile = "c:\test\file.txt"
strTemp = "c:\test\temp.txt"
Set objFile = objFS.OpenTextFile(strFile)
Set objOutFile = objFS.CreateTextFile(strTemp,True)
Do Until objFile.AtEndOfStream
strLine = objFile.ReadLine
' Remove last character from strLine
'This removes the carriage return and the last character and then adds the carriage return back
strFile = Left(strFile, Len(strLine) - 2) & vbCrLf
objOutFile.Write(strLine)
Loop
objOutFile.Close
objFile.Close
objFS.DeleteFile(strFile)
objFS.MoveFile strTemp,strFile
Martin,
should have mentioned I can't install external software not approved by out IT dept. But thank you for it.
Chris,
Thank you for the suggestion. I might try that but I'd prefer straight command line commands.
Here's are some links with suggestions that may help:
Delete last 2 characters from every line in a text file - Stack Overflow
for loop - Use Batch File Processing To Remove Last Character - Stack Overflow
Unfortunately I do not have access to some sites from work. Stack Overflow is one of them.
That's awesome. Thank you for uploading the pages.
Unforturnately, it doesn't look like it will work. The for command doesn't like the tilde character. I can do it outside the for command but that won't help. And using what they suggested doesn't output the line.
I DID IT!
I tried many different variations of what was on those pages. But I never tried the example where they used the CALL command. This is what worked. Or at least seems to have worked. I'l know once I get the mapkey and batch file all set.
Thank you so much.
SETLOCAL
for /f "delims=" %%a in (abc.pro) do (
set str=%%a
CALL :remove "%str%"
goto EOF
:remove
set str=%str:~0,-3%
echo %str% >> def.pro
:EOF
And just a little more information.
I also got a space at the end with this code. It's easy to remove that actually. I did some searching and found the answer.
Remove the spaces between the ">>" in the line echo %str% >> def.pro. That space adds the space at the end of the line in def.pro.
So now it's:
echo %str%>>def.pro
