Component Drag
dasher
Component Drag
How do I enable CTRL+Alt LMB for Component Drag?
I was able to do it prior to a new install on my machine and now I can't. Is there a config.pro setting I need? I thought it was a standard setting.
Thanks for the response.
I found the issue. enable_implied_joints no.
I just removed it and all good now.
psobejko
(To:dasher)
Maybe this one? modify_offset_during_comp_drag yes ?
